Serpentbane Posted March 29, 2010 Posted March 29, 2010 Recently the new satelite Thor 6 were lanched to the same location as Thor 3/5, and some of CD chanels were moved from Thor 3 to Thor 6 and given new frequensies. Over time. Thor 6 will replace Thor 6. Now, problem is I'm no longer able to find the "lost" channels. TV3 (Norwegian) among others. Thor 6 is not in the DVBViewer transponder list, but I tried manually adjusting the frequensy span to match Thor 6, but no luck. Anny ideas. This new satelite is no problem for people with CD tuners, and Dreambox users is also able to find the new frequensies with an search. We are two with this same problem. Quote
Serpentbane Posted April 2, 2010 Author Posted April 2, 2010 ..try this ini Ok. Thnx for the reply. I figured I'm supposed to place this in the Transponders folder? I'm rather new to this. I do have a file with this name allready, so I added a _B to the name of this new one. Is this OK? Anyways, am I sopposed to do something afterwards? I have not seen anny change so far. Quote
antz Posted April 3, 2010 Posted April 3, 2010 I figured I'm supposed to place this in the Transponders folder? I'm rather new to this.I do have a file with this name allready, so I added a _B to the name of this new one. Is this OK? You must overwrite the existing file and then do a channel scan (update only/update channel names) Quote
