lucianbalan Posted April 3, 2010 Posted April 3, 2010 (edited) I've installed versions from 3.9.2 up to 4.3 and all of them just close after about 25min. No error message or something. I want to buy it but I first I've wanted to try, so I used cracked versions. Tunner is Skystar 2 with 4.5.1 driver and windows 7. Any ideeas? Thanks. Edited April 3, 2010 by lucianbalan
lucianbalan Posted April 3, 2010 Author Posted April 3, 2010 (edited) My question is: if I buy it will work or will also stop after 25min? I don't like to throw away money even if is only 15 euros. I've search on forum and findout I'm not the only one. Thanks. Edited April 3, 2010 by lucianbalan
Griga Posted April 3, 2010 Posted April 3, 2010 if I buy it will work or will also stop after 25min? Legal versions don't stop after 25 minutes. BTW: Don't forget to carefully check your system for trojans that are frequently installed by cracked versions. I would re-install Windows, just to make sure.
Bossmann Posted April 3, 2010 Posted April 3, 2010 How can you even think that people would use a software that only works for 25 min? You must be joking???!!! Go ahead and buy! , its a amazing dvb- app.
lucianbalan Posted April 3, 2010 Author Posted April 3, 2010 (edited) thanks for fast reply's but I was not sure that 25min stuff is not an incompatibility with my configuration. I am an advanced user in IT but begginer in satellite stuff. We are an ISP and now we are trying to stream transponders with skystars into the network (free IPTV for our clients). Another problem we are facing is that not all the channels from our DTH operator are found at scan. The cables to the antenna are 61m long, high quality cables and 1m antenna. Standalone receivers are getting full list of channels. Could Skystar miss some of them? L.E. I will answer myself In the Transponders list it seems that Thor 3,5,6 is missing. Edited April 3, 2010 by lucianbalan
Griga Posted April 3, 2010 Posted April 3, 2010 Don't expect support here as long as you are using a cracked version. Would you go to a shop, steal something, and then come back and ask the owner for help? That's ridiculous. Topic closed.
Lars_MQ Posted April 3, 2010 Posted April 3, 2010 BTW for your intend you can't use the version for private use. And with the amount of criminal ernergy you showed, you don't honestly expect that a professional relationship is possible, do you? You better look around for another software you can steal...
