tosheva Posted April 8, 2010 Posted April 8, 2010 (edited) plz.. add signal bar in skin mode and osd in next version all other progs dvb have signal bar in skin mode and osd thanks Edited April 8, 2010 by tosheva Quote
xtonys Posted May 7, 2011 Posted May 7, 2011 miniEPG skin has this, but seems to only work if you have one satellite connected through one or more tuners. two satellites on two tuners and the signal quality only seems to work on one of two satellites. Checking against the status bar signal strength, miniEPG is 2% different, but at least it works. Signal quality, as well as signal strength would be good.... Quote
RedDwarf Posted May 28, 2011 Posted May 28, 2011 Signal quality, as well as signal strength would be good.... Yes, this would be nice to see as there are occasions when it would be useful. Maybe add it as another click option so that both can be selected between, because I don't think that both are needed all the time. Quality is most important. However, having both at the same time shouldn't take up any extra room. Maybe Q:85% S:80% or something like that and have the bar split in two with the Quality and strength above each other in slightly different colours. I have never liked bars because they are just not accurate enough. Numbers have much more meaning and are much easier to record. Showing what the numbers represent would be a good addition. A letter before them so they are easier to recognise. Quote
ZappoB Posted May 29, 2011 Posted May 29, 2011 Why do you not use OSD menu -> System -> Infos? If you need it more often, you can assign a key from your remote to it, or you can add it to the root of the OSD menu. Quote
