Nigel P Posted April 11, 2010 Posted April 11, 2010 Hi, I just upgraded my Recording Service from 1.5.0.31 to 1.5.0.101 to check out the iphone support (Excellent) but when I went to use my PCH to stream some live TV the native support no longer works. It times out with a error message "Request Cannot Be Processed". The standard UPNP streaming works fine within the PCH but I miss the extra bells and whistles that the native support gave. Is there a simple fix? I have got the Enable Popcorn Hour Support turned on. Thanks Nigel
noe99 Posted April 14, 2010 Posted April 14, 2010 (edited) I assume I have the same problem. On my popcorn-hour A-110 I have 2 DVBViewer-entries on the main-side: DVBViewer Mediaserver (hostname) -- works DVBViewer (hostname) does not work The message I get is: "eingabe nicht gültig" / invalid entry I only started working with DVBViewer and Popcorn-Hour recently, so I have never seen the second point working, but I assume this would give me also EPG on popcorn-hour kind of like the webinterface from recording-server? This would be nice. Thanks bruno support.zip Edited April 14, 2010 by noe99
noe99 Posted April 18, 2010 Posted April 18, 2010 I did find out what my problem was: When I change the port of the webserver back to 80 the DVBViewer on my poppy works. As soon as I change the port to something else then it does nolonger work here... The DVBViewer mediaserver on the poppy works with both settings. Bruno
Lars_MQ Posted April 18, 2010 Posted April 18, 2010 Confirmed and fixed. Thanks for the helpful hint.
