DVBViewer doesn't work(no video, black screen) after reinstall
lukah
I've reinstalled DVBViewer PRO v4.2.1 and now I have no picture (Support file attached).
Then I've switched from windows Vista to windows 7 and I've same problem.
I've tried to switch between video renderers, but nothing helped. I've also tried to instal FFDshow.
Any solution ?
Please help!
Yes I've checked those 4 options (see picture)
I've KNC1 TV station tv tuner
Edited by lukah
try to check only those with 4.2.1. Can you scan for channels in DVBViewer?
i'm not at home anymore I'll try it tomorrow.
Actually I didn't rescan channels, I've done import of channel list (EPG works,so channels are probably ok?)
thanks for help.
Hi. now I've installed only KNC DLLs for 4.2.1, same problem.
Now i'll try to rescan all channels.
Which KNC1 tv card drivers do you have?
I just noticed, that you don't seem to have installed the BDA(!) drivers for the KNC one card. Please reinstall them and check if you have hardware in the DVBViewer options.
Yes I've installed BDA drivers:
HW settings under DVBViewer setup looks also OK:
After channel rescan it works like a charm ! Thanks for help !
