Rec embeded icon don't disapear
themaster1
Bug detected today:
When i stop a recording (direct recording, not with the timer) the little icon in red "REC" won't disapear. If i go to full screen then go back the mini size everything is ok.
That's kind of annoying, you don't know if you're recording or not . One could miss many recordings just because of this bug
Edited by themaster1
I have forgotten: i use the 4.3.1.90 Beta, the standard version is ok as far as i know
How?
Use the current beta. reports for old betas are simply ignored.
