Using DVBViewer while RS is running?
blamand
Hi
After installing The DVBRecording service, I have no picture or sound when trying to watch tv in DVBViewer(both programs are on the same pc).
Am i correct in assuming that since RS has "control" over my hardware, it is not possible to both watch tv and having RS active on the same time? Or is it because i did not configure those 2 programs correct?
Best regards
First of all Thanks for answering Tjod
Im guessing that the answer is that I should be able to have Recording service running and watch tv on the same time?
I have been though the guide seveal times and i have searched the forum for an answer. But had no luck.
Would you be so kind to have a look at my supportfile and perhaps point me in the right direction?
Problem:
While RS is running i cant get any picture or sound in DVBViewer.
Specs.:
Tuner: Cinergy HTC USB XS
Driverversion: 5.9.1202.0
chipset of the mainboard and grafics card: Nvidia ION
Vers of graficsdriver:8.17.11.9621
Best regards
Edited by blamand
Thats it!!
All working now. Thanks for taking your time to answer me and pointing me in the right direction, Tjod.
Best regards
