Scraper 4 MyMovies Plugin
Hi all,
I've just finish the release of my movie scraper for the plugin MyMovies (only version 0.1.42 is supported).
It uses Cine-Passion database (a big thank to this team by the way).
I hope you'll find this useful, if you have any question and or remarks, please let me know in this topic.
Here to download : Scraper4DVBViewer :)
Scraper For DVBViewer 0.1 (ALPHA)
Prerequesites :
- DVBViewer pro with MyMovies plugin (only version 0.1.42 supported) installed
- .NET 3.5 (it's already installed if you have Windows 7)
HOW TO use it :
- Unzip all files into the directory of your choice.
- Launch "Scraper4DVBViewer.exe"
- At first launch:
- If your movies DB File is not found, a dialog box asks for it
- A new dialog pops up asking you a directory where all grabbed images will be placed
- Movies are splitted in 2 types : Rip (avi, mkv, etc..) or Disc (DVD/BluRay).
- The easiest way to add a movie:
1.In disc or rip tab, go into the grid and enter the title in the title column.
If you have the IMDB ID of the movie, you can write it in IMDB ID column instead of entering the title.
2.Make sur the line is validated (type enter), then click on square on the lefter column. It will select the line.
3.Click on the "Scrap !" black button (closed to the blue save button).
4.If movies corresponding are found, a list appears and asks you to choose the one you want.
Select and click on "Scrap".
5. That's all !! Oh... don't forget to click on the save button (otherwise all you've done is lost)
- You can switch between French/English for your movies info within the menu.
- MultiSelection is possible
NOTE :
- if you have entered a title AND a IMDB number, the scraper will only try to find using the IMDB ID.
Enjoy ;)
Galerio.
