poseidon9000 Posted April 18, 2010 Posted April 18, 2010 Hello from Spain, sorry for my english. I have just installed the technisat Skystar 2 HD and i have found a trial version of DVBViewer before purchase the program. Is it possible?? Quote
amontillado Posted April 18, 2010 Posted April 18, 2010 Hello from Spain, sorry for my english. I have just installed the technisat Skystar 2 HD and i have found a trial version of DVBViewer before purchase the program. Is it possible?? No there is no trial version available. You can test if DVBViewer will work with you hardware with transedit (download from DVBViewer homepage) And the answer to most of the functional questions can be easily found on this forum. (also check out the OSD section of the forum for some impression of what the current skins for the OSD look like. Quote
Gioxy Posted April 20, 2010 Posted April 20, 2010 No there is no trial version available ...probably poseidon9000 was referring to "DVBViewer TE2" bundled with his card... Quote
Gioxy Posted April 20, 2010 Posted April 20, 2010 @poseidon9000: There are two DVBViewer versions, TE (Technisat Edition) and Pro and the difference is explained here, even though the page is not so up-to-date and there are several new function/feature missed in it for both; eg TE now are TE2... Quote
poseidon9000 Posted April 25, 2010 Author Posted April 25, 2010 (edited) Thanks, not , I have DVBViewer TE2 and I have just buy by paypal the DVBViewer Pro. DVBViewer go well with my skystar2 HD Edited April 25, 2010 by poseidon9000 Quote
