patti Posted April 20, 2010 Posted April 20, 2010 Hello Here is an idea for DVBViewer that I would find most useful. At the moment DVBViewer has DisableAV functionality but it just blanks the screen but does not turn off the display to power save mode like windows power options do. From the point of saving electricity and having an even more enjoyable experience it would be useful to have a "turn off display" function for DVBV like the one in Windows power options. Thus you could use your remote to turn off the display for example when going to sleep and let recordings finish in the background without having to get up from bed Yeah, I'm lazy and do not want to get up from bed to turn of the display... Also this turn off display function would be most welcome for scheduled recordings when started from hibernate. This way it would be made certain that DVBV uses the minimum amount of energy when left unattended. If the user wants to resume watching live TV after DVBV has been started from hibernate a simple click on mouse or a remote press would bring the display back to life. patti Quote
Tjod Posted April 20, 2010 Posted April 20, 2010 Thus you could use your remote to turn off the display for example when going to sleep and let recordings finish in the background without having to get up from bed Options > Input >> add a new group >> add a new command with two actions > 1. Stop Graph, 2. Shutdown Monitor Quote
patti Posted April 20, 2010 Author Posted April 20, 2010 Oh, it already exists, thanks. How about that second part, turning off monitor when woken up from hibernate? patti Quote
Tjod Posted April 20, 2010 Posted April 20, 2010 add -x16383 -x12328 as Special Start parameter (not tested) Quote
patti Posted April 21, 2010 Author Posted April 21, 2010 (edited) Hi, I found an easier way to do this shutdown monitor when scheduled recordings start. I simply put Windows 7 to turn off the display after 1 minute. If recording service starts the computer and DVBViewer does not have an active graph in it then the monitor will sleep in 1 minute. If I have an active graph in DVBViewer then the monitor stays on as it is supposed to do. One more idea remains on my wishlist regarding monitor powersavings: an action for DVBViewer to activate the monitor again with remote after it has been put to sleep. That would have all aspects covered: shutdown/wakeup monitor by remote and shutdown monitor when started for scheduled recordings. thanks patti Edited April 21, 2010 by patti Quote
Griga Posted April 21, 2010 Posted April 21, 2010 an action for DVBViewer to activate the monitor again with remote after it has been put to sleep. It's easy to make a small exe file that switches the monitor on. According to this it only requires one line of code: PostMessage(HWND_TOPMOST, WM_SYSCOMMAND, SC_MONITORPOWER, -1); Maybe someone knows how it can be integrated... Quote
patti Posted April 21, 2010 Author Posted April 21, 2010 After using my brains a bit I realised that Girder allows sending mouse clicks or key presses to Windows so I mapped a remote key to mouse left click and now I can wake up my monitor from sleep. Everything's covered now, but this feature would be quite useful for a built in DVBViewer action too. Thanks for the hints that led me to solutions patti Quote
