Mystique Satix-s2 CI-Module not recognized/working?
but only on DVBViewer pro or pro beta while it works as expected under mystique tv which is also a DVBViewer based player... but myustique-tv player is a little old and having discontinueties all the time and I believe its because of its old tech.
so i'm confused really and I need help from DVBViewer professionals :S
PS: there are 2 different/extra files in the mystique-tv player's folder; "KNCBDACtrl.dll" and "ttBdaDrvApi_Dll.dll" and other then CI modul dvb-s2 card it self works like a charm but its useless to me if CI module doesnt work... :(
I'm using w7 64bit...
tried 2 different knc bda drivers (2.0.1016.0 and 2.1.202.0) so far no luck...
thanks in advance
Removed post because I mistook the DVB-Card for the dual S2 card.
The KNCBDACtrl.dll is the right one. Did you also download the MS C runtime in the setup?
UPDATE: I figured and re-run the DVBViewer setup with knc-ci support selected this time and now its working BUT now I have an other big problem; only on DVB-S2 channels it is having 50~ discontiniuties PER MINUTE! so its no use... :(
please help me :S
