PiP and changing audio volume
patti
Hello, currently you can watch one channel on the main screen and switch to another channel's audio with the help of a PiP window. This is great for situations when you want the video from one provider and audio from another. For my case it is picture from one Eurosport provider and PiP audio from another Eurosport provider (before you ask, the picture formats are different hence the need for PiP audio). The only problem is that once the PiP window's audio has been brought to foreground audio volume adjustment of that audio track is not possible unless you bring the PiP window to main screen. This is highly impractical.
So my wish is that which ever audio is on the foreground, the PiP or the main screen, the volume keys on my remote would adjust that volume. With the current behaviour of DVBViewer the volume keys only adjust the main screen's audio volume resulting in two different audio tracks being mixed together.
thanks,
patti
Edited by patti
