Recording of DVB Subtitles
majstang
Hi!
Hackbart informed about an option which enables recording of DVB subtitles in this thread
http://www.DVBViewer.info/forum/index.php?...st&p=295867
You could also try to record the subtitles with Transedit, or if too complicated select TS as output and enable the ability to record subtitles under options. A few MB should be enough to find out what went wrong.
Cannot get it to work. I have .ts output format choosen and DVB Subtitle and Adjust PAT/PMT enabled. Plenty of DVB subtitles when watching live in DVBViewr pro 4.2.1, no DVB subtitles when playing the recordings in DVBViewer nor TSPlayer. How is this supposed to work?
TSPlayer doesn't support dvb_subs. You could check with vlc whether the recording contains the subtitles. Maybe there aren't any :biggrin:
Well, during my second sitdown trying to get this to work i did noticed my DVB Subs was named Teletext and when enabling them in Format Options it works. My bad :biggrin:
