patti Posted April 26, 2010 Posted April 26, 2010 (edited) Hello again, is it possible to somehow detect via a script whether DVBViewer has an active graph or not? I've been through the COM helpfile from members area but could not find anything regarding graph. I'd like to script a task for recording service to detect whether tehre is an active graph or not and shutdown/keep computer on accordingly after a recording finishes. thanks again, patti Edited April 26, 2010 by patti Quote
Tjod Posted April 26, 2010 Posted April 26, 2010 If you are working with the COM Interface I would recommend DVBViewer Spy (Members Section). May be it works if you test for #TV.audio.pic Quote
Lars_MQ Posted April 26, 2010 Posted April 26, 2010 just do a (GetActiveObject(CLASS_DVBViewer, nil, unknown) <> MK_E_UNAVAILABLE) to see if a running instance is in the ROT. Quote
Lars_MQ Posted April 27, 2010 Posted April 27, 2010 OK this was for detecting the DVBViewer itself. The best way to detect if a graph is active: if DVBViewer.OSD.isplaying = true then To get the graph itself you would have to examine the ROT. Quote
patti Posted April 27, 2010 Author Posted April 27, 2010 Thanks for a quick answer. Working on my script ... Quote
