miro111hrzg Posted May 2, 2010 Posted May 2, 2010 (edited) Hello, I have a problem with latest DVBViewer beta version 4.3.1.120 on channel change action ( it didn't worked on DVBViewer version 3 either) : a) at the Hotbird 13E - channel called VideoBergamo ( 11013H FEC 3/4 27500) no picture on it after channel change - I have to choose option rebuild graph and even then sometimes there is no picture only sound until I set the Video Output B with different graph settings. b ) at the Astra 28,2E , transponder 11261H no picture and sound , signal is always ZERO on all channels of that transponder until I click on rebuild graph, and then is everything normal (maximum signal strenth is 40% - logical for my dish position), but after lurking on the other channels and coming back on the same transponder - same story - no signal no sound no picture! Very strange. I tried with different decoders but situation was worse , so I left most stable option for most channels. Support zip is attached. Also, is it possible to set rebuild graph on every channel change or using video output B on some channels? support.zip Edited May 2, 2010 by Griga Quote
Griga Posted May 2, 2010 Posted May 2, 2010 VideoBergamo That's interesting: 352 x 288 resolution, the ffdshow video decoder immediately lets the whole app crash (auto-closed by Windows), but the Cyberlink video decoder can cope with it after some initial difficulties. Bad resolution and/or bad MPEG2 encoding I'd say... Astra 28,2E , transponder 11261H Did you already try Options -> Hardware -> Retune on missing stream after... (e.g. 3 seconds)? Quote
miro111hrzg Posted May 3, 2010 Author Posted May 3, 2010 Did you already try Options -> Hardware -> Retune on missing stream after... (e.g. 3 seconds)? Yes I tried - not works. I also tried to turn the satellite dish for astra2 today, but it's strange that signal quality is 57% and then suddenly goes to 10% and then to zero and again t0 ~ 50%. I will contact Astra to see what is going on with that transponder. Quote
miro111hrzg Posted May 4, 2010 Author Posted May 4, 2010 I figure it out! My DECT phone was very close to tv and it was making noises on the vault transponder 11642 V at Astra 2. But still problem with DVBViewer graph exists. When I go from Thor channels back to Astra each time I need to rebuild the graph to get exactly real signal and picture with sound from that and few other transponders! Quote
