How slow can you go? With 2x DVB-S
chrlau5
Hey
I admit I am trying to push my system to the LIMIT!
I have got a P4 3,0 Ghz computer running Win7 + Latest BETA´s of DVBViewer and Recording Service.
2 x DVB-S1/S2 cards. Hauppauge NOVA and Tevii USB S660
Live TV runs fine no problems also HD channels are ok.
My problem is that when I use both cards at the same time I get errors in the recordings. Does not matter if I record 1 channel and watch live tv on another channel or if I record 2 channels at the same time.
Whenever I use both cards there are errors in the recordings.
The CPU usage is "only" at about 50-60 percent so I don´t understand why I get these errors???
Any suggestions or is it simply my old computer that is to slow although CPU is not at 100%.
I don´t know how to edit my posts?
By the way it does not matter if I record 2 SD channels or watch 1 SD channel + record another SD channel.
With HD channels same problem.
I can see the errors in the log and in the webinterface of the Recording Service and the recorded movies are as close as possible to be unwatchable.
It's most likely a hardware/driver problem. Do the errors occur if you switch channels? Do you use Diseqc?
Hey
I am using 2x Spaun 2/1 Diseqc
I have the newest drivers from Hauppauge and Tevii installed.
I have tried both with the RS "owning" the tuners and with DVBViewer "owning" them. It did note make any difference.
Watching 1 channel or recording 1 channel at a time is no problem.
Errors occur even when I am only recording 2 channels without watching 1 of them.
Errors also occur if I am wathcing 1 channel and recording 1 channel at the same time.
FTA or paytv? If the latter, what CI?
FTA+Pay - [deleted]
§ 13 (Forum rules)
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combi­nation with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common inter­face" (CI) with a smart-card. This applies re­gardless whether software-descrambling is allowed in your country or not.
