Live Streaming over internet.
Bartel
Hey
I'm new to DVBViewer and got some questions.
I got DVB recording service to work, I can watch channels live over the internet and thats great.
But my problem is I can't use DVBViewer at the same time (and that is a little problem).
Ain't there a way so I can use DVBViewer to stream direct to WMP like a (mms://192.168.1.90:1234) address? and at the same time can watch it on my host machine
Thanks, that helped alot.
Got another question, I can watch two different channels on my DVB-C tuner, if they are in same frequency like in 594MHz.
Is it possible to watch a channel from frequence 594MHz and 490MHz at the same time ? or do they have to be in the same frequency?
btw my tuner is a Cinergy C PCI Digital Tuner.
If you have only one tuner no. If you have two tuner yes.
can you watch 2 different channels from 2 different pc
in the home network at the same time
regards wikings1
Yes if the channels are on the same frequency and not encrypted.
If you have more Tuner you can watch channels on different frequency as well.
