Incorrect displaying of one of my HD-channels
ginnie
I found a strange behavior of DVBViewer on one of my HD-channels. TS-file to reproduce the problem can be found here (from 16-th second of the file, see the timer in the lower right corner).
..no problem here.. ..plays just perfect (cyberlink pdvd9, overlay)
I have the problem with DVBViewer 4.3.1.140 beta (Cyberlink or Microsoft DTV-DVD Video Decoder or MPC H.264 decoder, EVR Custom renderer) + Windows 7
Edited by ginnie
I don't see a problem. Must be your system.
I have no problem with VMR9, only with EVR (Custom and Enhanced). Also I have no problem in MPC + EVR Custom renderer.
Well since you never even cared about telling WHAT your problem is, I don't care about helping you. ^_^ You'll have to live with your problem. :bounce:
Lars_MQ, I am sorry! It is not so easy to describe my problem. It seems like parts of the old frames are superimposed on the new frames. I made successive screenshots (45 Mb).
