Resource Library
evgen_ln
I am working on a new version of the Russian language file (and possibly Ukrainian later). In the process I was faced with the fact that the English (German) language is more compact than Russian. Minimum required text can't be fit in the allotted space always. I must sacrifice the meaning or make reductions that are not always desirable.
Suggestion. Resource Library (which can be changed if necessary) to use in addition to language file. The library should be used if found for the current language, if not found must be used standard.
