TGM Posted May 13, 2010 Posted May 13, 2010 Hi there I am having big problems getting my channellist from the TransEdit_IPTV into my DVBViewer configuration. I have tried this with both DVBViewer version 4.2.x but also with the beta version 4.3.1.140. I used the TransEdit_IPTV version 3.9.0.2, where I make a Blindscan for my IPTV channels, and that works. But when I will export the channellist to the DVBViewer, it errors with the message "Sorry - cannot export since DVBViewer 2.1 (or later) is not present", but I have installed the version 4.3.1.140 (and earlier version 4.2.x). Then I save the channellist into a file, but when I try to import that file into the DVBViewer using the Channel configuration/Import menu in DVBViewer, it loads the file, but the channel list is empty. How do I transfer my channellist to my DVBViewer? Thanks Br TGM Quote
Lars_MQ Posted May 13, 2010 Posted May 13, 2010 Put the transedit.exe into the DVBViewer program folder. Quote
TGM Posted May 13, 2010 Author Posted May 13, 2010 Tried that, still same error message from TransEdit IPTV program Quote
TGM Posted May 14, 2010 Author Posted May 14, 2010 I managed to get it to work by using an old ini file from my xp installation, now I somehow got all the channels into DVBViewer, but I still dont know how to transfer new channels into the program. But my initial problem is solved, so please close this case Quote
