The best picture settings
wikings1
Hello i wonder whats the best codec and settings for picture quality
to day i use latest DVBViewer beta.
my config
Tv Lg 50pc51
grafik card nvidia 250 whit 1 gig memmory
nvidia settings deafault
latest nvidia driver
using hdmi out and 720 p little customized desktop
no zooming right now or stretshing
the hdmi is connected tru my cinema reciever whit hdmi harman kardon avr 255
and from that hdmi to tv
i think the picturequality is poor
so pleas help me to optimize the dvdviewer picture quality
regards wikings1
You have to set up the correct decoder and renderer.
Test it!
If you are using Win 7, all is build in, otherwise i would recomend CoreAVC
You could try to configure your PC to the native resolution of your TV (i belive it is 1366×768) and configure the refresh rate to 25, 50, 75 or 100 hz.
yes i am using win 7 64
så i dont need any codec pack
only instal DVBViewer and choose custom render
and deafault decoder .
is that the best choice
Yes, it is, but you also need to use the best resolution and refresh rate
