DVB Server
vondoogle
Is there a user manual for setting up the Dvb Pro Server? Is it designed to stream media to other device via multicast? I can use VLC to stream recorded video to another PC on my network, but couldn't get the Pro server to do the same.
When I put in a multicast address in the settings it stays red but is in the correct multicast range?
Von
It's way better to use RecService instead of DVBViewer Server, look here why...
To set up it there is a Recording Service Installation Guide in the Wiki; please follow ALL instructions, especially how to configure the DVBViewer client part...
Anyhow at the end of the former mentioned post thare are a link to a DVBServer setup guide...
...hope it helps...
Have a look at my setup for DVBServer
http://www.manikata.com/it/DVBViewer/index.htm
Frank
Von
Thanks for the replies guys, I will have a good read through and a play at the weekend and see if I can get things going, just one quick question If I use DVB server to broadcast I should still be able to get the stream (multicast) on the remote PC with VLC right?
Von
No the DVBServer is for DVBViewer Clients only.
Use NetStreaming Plugin or Recording Service > web interface for VLC player clients.
