Really little bug: Minimize blocked.
SirDester
Hi all,
I recently bought the Pro version of DVBViewer and configured it to be launched by DVBScheduler at determined scheduled times (using windows scheduler command DVBScheduler -x).
I noticed this little bug that, when the DVBViewer opens, the "Minimize" button is blocked, even if clicked the program doesn't minimize itself in traybar.
If I maximise the window at least one time (with double click or using the Maximize button), then I can correctly minimize the application in traybar.
This problem does not occur if I launch DVBViewer manually from it's executable.
Thanks for all your work.
Bye.
Ok, I installed new beta version 4.3.1.150 and I saw that the minimize problem after DVBViewer opened with scheduler has been solved (read that on the Changelog too).
Thank you very much, you can close this.
Bye.
