Something strange
evgen_ln
Something strange is happening with the DVBViewer. A few seconds after start program make sounds like an alarm siren. What does this sound can be caused? How does this sound off?
There is no code at all doing a siren. ;)
Most likely a audiorenderer or audiodecoder thing :P
Strangely, оther programs with the same codec settings working properly. And this strange signal occurs only after the DVBViewer launch. In any case, I run a virus scan. I will look for the problem. I do not want to reinstall the DVBViewer.
I found the cause. I had the myInternet plugin installed . Start Page is set to www.google.com with the game Pac Man as a logo. The game is a flash, the alarm sound is a part of it. Problem solved by replacing the home page.
I'm starting hates Google :P
Edited by evgen_ln
Well, did the siren come up from the beginning or did it just happen "suddenly without you having touched your PC except for installing 500 different programs and other trash"? :P
Read the answer above....
:P I like if problems solve this easy ;) ;)
