janip Posted May 27, 2010 Posted May 27, 2010 Is there any change to get instant timers work, or how i can avoid that "No hardware available" error? Do i need set up two unicast device, but maybe that won't work only one service?
Devastation Posted May 28, 2010 Posted May 28, 2010 (edited) you can (should) create a unicast for each DVB device http://en.DVBViewer.tv/wiki/Recording_Serv...Unicast_Devices Normally a Service timer has higher priority. If instant and programmed timers collide you will have another "No hardware available" if not on same transponder. Edited May 28, 2010 by Devastation
janip Posted May 29, 2010 Author Posted May 29, 2010 (edited) Is that true? Recording service use all my four dvb-c cards, shoud i really create four unicast device? I was thinking that rec.service is only one unicast device, no matter how many device it use. Edit: Yep, maybe i just have to belive. Edited May 29, 2010 by janip
Devastation Posted May 29, 2010 Posted May 29, 2010 It s not really a must, but it will help to avoid your problem. Also its needed for Picture in Picture (if not same frequenzy).
