How to close DVBViewer using a command?
calande
Hello,
I found a list of commands that I can use to control DVBViewer. All of them work, except the "Close DVBViewer". When I execute it, I get a confirmation dialog asking if I really want to close DVBViewer. As I'm executing this command from a remote control, I can't move to the "Yes" button and hit "Enter". How to close DVBViewer using a command?
Thanks,
Options---General--Shutdown and setting Timeout for shutdown warning to 0 should fix that, i think.
Thanks. I found out:
Options » General » Shutdown » No confirmation on Exit
o:)
  • 4 weeks later...
you can use AutoIT if you want to get more control.AutoIT is relative profressional tools for controling many aspects of computer.
