enable ci on terratec s7
Is it possible to enable the CI-interface on Terratec s7 in DVBViewer?
Works great here!
It does work with the current Beta. To get it to work with the 4.2.1 you have to edit the hardware.xml. If you post your support.zip, i'll help with that. o:)
Lars,
Here is the support.zip.
Does it also work with dvbserver? I use that.
Thanks, Eppo
Well, there was no server hardware xml file, but if you change device name according to the attached files it should work.
The svchardware.xml has to go in the subfolder \config\ of the userdata folder. And if active you have to stopp the service first.
hardware.zip
Hi Lars,
i tried to override my svchardware.xml with your. It worked very good for a few minutes but now the problem is still the same.
I can watch encripted channel just for a few seconds and then the stream freeze.
I don't understand what is wrong.
Thanks
Shipoftrip
Sorry, here there is my support.zip attached.
Edited by shipoftrip
I don't understand...
I can not edit my posts and i can not upload my support.zip.
I try with this post.
Lars,
Channels and switching all works fine. I can also see the cam + smartcard on clients using the recording service.
However, no decoding. It keeps telling me i have no rights but i know the card is ok because i can verify that in regular tuner. Have you been able to receive through subscription using the recording service?
Regards, Eppo
