ter9999 Posted June 27, 2010 Posted June 27, 2010 Is there possibility to convert 2D content into anaglyph 3D in real time (just like Sim3D in TMT3) by a shader? Also, the 3D options were integrated in ProgDVB: Quote
alec1976 Posted July 1, 2010 Posted July 1, 2010 Is there possibility to convert 2D content into anaglyph 3D in real time (just like Sim3D in TMT3) by a shader? nope , u have to use direct show filter instead here u go , PostProcessor.ini for 3Dfier 2d to 3d filter : [setup]PostProcessor=3Dfry 2d-to-3d transformer AudioPostProcessor=None Version=513 WMAMultiChannel=0 [Postprocessors] CLSID.0={0B390488-D80F-4A68-8408-48DC199F0E97} Name.0=ffdshow raw video filter CLSID.1={0524CEA7-7E7D-4804-8A7B-D17A99807D3C} Name.1=NVidia Postprocessor CLSID.2={3BAFDCB6-8CF6-4D08-9FCE-2D2883A9FB32} Name.2=Creeo Postprocessor CLSID.3={F9BA22CA-0704-45EE-A8F9-AC246411A6FA} Name.3=MoMoLight CLSID.4={5E356343-12E3-4949-B92E-938222A58E94} Name.4=3Dfry 2d-to-3d transformer [AudioPostprocessors] CLSID.0={A753A1EC-973E-4718-AF8E-A3F554D45C44} Name.0=AC3 Filter CLSID.1={B86F6BEE-E7C0-4D03-8D52-5B4430CF6C88} Name.1=ffdshow Audio Processor CLSID.2={0BEDA08A-C516-4A44-9141-7B2CF28975EA} Name.2=InterVideo Audio Processor CLSID.3={B38C58A0-1809-11D6-A458-EDAE78F1DF12} Name.3=DC-DSP Filter Quote
madsilence Posted August 21, 2010 Posted August 21, 2010 ............. -activate the shader in DVBViewer Stupid question....How to activate the shader in DVBViewer??? I use 4.3.1.165beta + WinXP SP3..any limitations? Quote
madsilence Posted August 21, 2010 Posted August 21, 2010 I had to download this http://www.microsoft.com/downloads/en/confirmation.aspx?familyId=3b170b25-abab-4bc3-ae91-50ceb6d8fa8d&displayLang=en to activate EVR Renderer on XP. Then main submenu View/Shaders appears...and works fine.. Thanks to developer. Smart and simply solution. Good work. This maintains DXVA working !!. I remind that Stereoscopic Player plays 3DTest files but doesnt support DXVA on Cyberlink codecs. Quote
madsilence Posted August 23, 2010 Posted August 23, 2010 (edited) Hi again. Is there any simple way (shader-like, without stream recode) implement Pulfrich method based on Pulfrich glasses???? these ones http://cgi.ebay.es/ws/eBayISAPI.dll?ViewItem&item=260653838453&ssPageName=STRK:MEWNX:IT (only as example, I mean no advertising but there are very poor choice to buy) Anyone can make these glasses at home extracting one glass (left or right indifferently, but only one of them) IMHO colours are better than with anaglyph glasses. Obviosly we loose a vertical resolution obtaining better colour scheme. There is a Kamasutra 3D DVD5 on the net for wieving with this method...so anyone can test this simple and cheap way of stereoscopic movie. Thanks in advance. Edited August 23, 2010 by madsilence Quote
Dirk Hartstein Posted October 4, 2010 Posted October 4, 2010 (edited) Hello, is there a possibility to use instead the red/cyan glasses the „ColorCode"-3D format? Is there a way to change the shader? kindly regards, Dirk Edited October 4, 2010 by Dirk Hartstein Quote
hackbart Posted October 4, 2010 Author Posted October 4, 2010 You can easily change the shader or create another one. There is no real magic behind such a thing and there are a lot of manuals to explain how to deal with the HLSL language. Quote
Dirk Hartstein Posted October 4, 2010 Posted October 4, 2010 (edited) You can easily change the shader or create another one. There is no real magic behind such a thing and there are a lot of manuals to explain how to deal with the HLSL language. Thanks for your reply. Unfortunally I don't have the experience to do this. Would it be possible to do this for me please? kindly regards, Dirk Edited October 4, 2010 by Dirk Hartstein Quote
Oliver B Posted October 8, 2010 Posted October 8, 2010 (edited) These are the parameter for colorcode 3d (from wikipedia) The blue filter is centred around 450 nm and the amber filter lets in light at wavelengths at above 500 nm. Wide spectrum colour is possible because the amber filter lets through light across most wavelengths in spectrum. When presented via RGB color model televisions, the original red and green channels from the left image are combined with a monochrome blue channel formed by averaging the right image with the weights {r:0.15,g:0.15,b:0.7} http://en.wikipedia.org/wiki/ColorCode_3D#ColorCode_3D Edited October 8, 2010 by Oliver B Quote
travelland Posted October 10, 2010 Posted October 10, 2010 Is it possible to activate the anaglygh shader automatically after switching to a side-by-side channel and deactivate after switching to a SD or HD channel? Quote
bobbel182 Posted October 25, 2010 Posted October 25, 2010 Hello, is there a possibility to use instead the red/cyan glasses the „ColorCode"-3D format? Is there a way to change the shader? kindly regards, Dirk Hi Dirk, I made a ColorCode Shader File. I'm a beginner in 3D but I think it looks not bad Maybe somebody can optimize... anaglyph_cc.xml Quote
ricabullah Posted October 25, 2010 Posted October 25, 2010 Here is what it is; what i see without glasses via DVBViewer 4.5. Does it mean if i wear the glasses i gonna get 3D ? Quote
desweil Posted October 26, 2010 Posted October 26, 2010 yes (If you are watching a sidebyside 3d transmission that is!) Quote
h4xx0r Posted October 26, 2010 Posted October 26, 2010 (edited) Is it possible to watch 3D with this glasses? (Passiv: Polfilter (radial)) http://de.wikipedia.org/w/index.php?title=Datei:Glasses_for_RealD_Cinema.jpg&filetimestamp=20100313142741 Ot is there a way to change the colors to work with green/Magenta? http://www.hama.de/bilder/00084/abb/00084423abb.jpg KR Edited October 26, 2010 by h4xx0r Quote
bobbel182 Posted October 26, 2010 Posted October 26, 2010 Is it possible to watch 3D with this glasses? (Passiv: Polfilter (radial)) http://de.wikipedia.org/w/index.php?title=Datei:Glasses_for_RealD_Cinema.jpg&filetimestamp=20100313142741 Yes its possible, but I think you need a 70000+ Euro Cinema equipment ;D Ot is there a way to change the colors to work with green/Magenta? http://www.hama.de/bilder/00084/abb/00084423abb.jpg KR You can try the shader file in the attachment... anaglyph_gm.xml Quote
feezel Posted October 26, 2010 Posted October 26, 2010 Hi There, how can i activate the "Alaglyph Shader"? I copied the .xml file into .../dvbvieder/shaders But i still have the following Picture: thanks! Quote
feezel Posted October 26, 2010 Posted October 26, 2010 oh...thats's to easy.It would never have occurred to me. Thank you! Quote
Dirk Hartstein Posted October 28, 2010 Posted October 28, 2010 Hi Dirk, I made a ColorCode Shader File. I'm a beginner in 3D but I think it looks not bad Maybe somebody can optimize... Hi, you did a fantastic job. It looks very good and the colours are much better than with the red/cyan glasses. Thank you very much. I can't see anything that must be optimized. kindly regards, Dirk Quote
welcome Posted October 29, 2010 Posted October 29, 2010 @bobbel182 @all Can you made a shaders file for the following glasses......I've 3 glasses but still can not 3D TV correctly. http://i.ehow.com/images/a04/pn/s5/make-game-glasses-800X800.jpg http://www.studio3d.com/images/For_Sale/ana_cyan.jpg http://www.3dglassesonline.com/sites/default/files/imagecache/lightbox-image/photo_images/E-commerce-Pictures-for-Centre-028.png Quote
bobbel182 Posted October 29, 2010 Posted October 29, 2010 (edited) Hi, you did a fantastic job. It looks very good and the colours are much better than with the red/cyan glasses. Thank you very much. I can't see anything that must be optimized. kindly regards, Dirk Thank you, but it was Hackbarts code making this possible, I only found the right values Anyway, I customize/optimize the ColorCode Shader. I think sometimes this shader looks better. @bobbel182@all Can you made a shaders file for the following glasses......I've 3 glasses but still can not 3D TV correctly. http://i.ehow.com/im...ses-800X800.jpg http://www.studio3d....le/ana_cyan.jpg http://www.3dglasses...-Centre-028.png The second one is Red/Cyan. Take the code of the first page or check the shader folder (anaglyph.xml) and the third one is Green/Magenta, check my shader file on page 4. anaglyph_cc2.xml Edited October 29, 2010 by bobbel182 Quote
welcome Posted October 30, 2010 Posted October 30, 2010 I can see 3D feature with anaglyph.xml (on first page) and your anaglyph_gm but i can not watch like normal TV so the colors which i see with glasses not correct than the original picture (non-shaders) Quote
pinuxxp Posted November 1, 2010 Posted November 1, 2010 It works only in beta version of DVBViewer? Quote
hackbart Posted November 1, 2010 Author Posted November 1, 2010 No, this works fine in the current official DVBViewer version. Quote
ricabullah Posted November 6, 2010 Posted November 6, 2010 Dear Devs, Finally got one pair of 3D glasses and gave it a go. I think we are at the beginning of 3D road. Pls give it a go to compare. Here is the stereoscopic test movie: 3D test movie Here is the other player for test: Stereoscopic Player And here are the screen caps: DVBViever: Stereoscopic Player: _ _ _ _ _ Quote
ricabullah Posted November 6, 2010 Posted November 6, 2010 This is crazy but someone told me to check my "DVBViewer Cap" with the glasses on the reverse side; right is magenta, left is cyan and it works: at least i get 3D even the colors are not natural. Quote
ricabullah Posted November 7, 2010 Posted November 7, 2010 (edited) With this attached reverse script (by malcolm58 from turkeyforum) 3d glasses work (right cyan, left red): Now, it's time to correct the colors as well. _ _ _ _ _ Anaglyph_Reverse.xml Edited November 9, 2010 by ricabullah Quote
oesi Posted November 9, 2010 Posted November 9, 2010 Is there a way to use easily my 3D Beamer and the nvidia kit with Sky 3d? Is it possible to implement it? Regards Quote
ricabullah Posted November 10, 2010 Posted November 10, 2010 Really i wonder what Sky 3D offers? When you tick "none" under "View" > "Shaders", what do you see: side by side or just one screen? Quote
Pynkyz Posted November 10, 2010 Posted November 10, 2010 (edited) Really i wonder what Sky 3D offers? When you tick "none" under "View" > "Shaders", what do you see: side by side or just one screen? A screen divided in two, where each of the two parts shows (almost) the same image; and that is a pure "side-by-side" 3D transmission. Edited November 10, 2010 by Pynkyz Quote
ricabullah Posted November 11, 2010 Posted November 11, 2010 (edited) A screen divided in two, where each of the two parts shows (almost) the same image; and that is a pure "side-by-side" 3D transmission. Thanks for the response. BTW with this attached xml (by malcolm58) and while "Hue" is increased around 10%, colors seem very close to as SP shows: BTW both PDVD10 and DVBV Pro use the same windows filters. (for this sample) and both give the same result with above advice. Anaglyph_Reverse_new.xml Edited November 12, 2010 by ricabullah Quote
Pynkyz Posted November 12, 2010 Posted November 12, 2010 (edited) Thanks. Do you think you could write a shader that does page flipping of a side-by-side transmission? Edited November 12, 2010 by Pynkyz Quote
sw4y Posted November 12, 2010 Posted November 12, 2010 @ ricabullah How do you make it look like the one in the picture when playing back the file with DVBViewer? I tried it but I got two pictures (up and down), DVBViewer used the windows media decoder (wmvdecod.dll)... When I play in Powerdvd 10 (trial) I get the same result until I press the "3D-Button"... Is it possible to play the file in DVBViewer with Powerdvd Codecs? Otherwise, how did you do it? Quote
evgen_ln Posted November 12, 2010 Posted November 12, 2010 (edited) Do you think you could write a shader that does page flipping It is not possible. The best way to implement page flipping is a DirectX filter or a special renderer (this can be implemented by writing a custom allocator and presenter). At present, if you choose from the available PC technologies NVIDIA 3D Vision will be the best choice. NVIDIA offers an open API for its technology. NVIDIA 3D Vision support could be easily implemented in DVBViewer, this requires only developers desire. This is my main suggestion for future versions. Edited November 12, 2010 by evgen_ln Quote
ricabullah Posted November 13, 2010 Posted November 13, 2010 (edited) Is there a way to use easily my 3D Beamer and the nvidia kit with Sky 3d? Is it possible to implement it? No, sorry; i'm not a coder. @ ricabullah How do you make it look like the one in the picture when playing back the file with DVBViewer? I tried it but I got two pictures (up and down), DVBViewer used the windows media decoder (wmvdecod.dll)... When I play in Powerdvd 10 (trial) I get the same result until I press the "3D-Button"... Is it possible to play the file in DVBViewer with Powerdvd Codecs? Otherwise, how did you do it? PDVD and DVBViewer use the same Windows filters on my trial 3D movie. How to enable 3D effect on DVBViewer: Copy "Anaglyph_Reverse_new file to DVBViewer > Shaders folder. Open DVBViewer and select Anaglyph_Reverse_new under View > Shaders. And restart the program and wear your red-cyan glasses. _ _ _ Edited November 13, 2010 by ricabullah Quote
sw4y Posted November 13, 2010 Posted November 13, 2010 PDVD and DVBViewer use the same Windows filters on my trial 3D movie. How to enable 3D effect on DVBViewer: Copy "Anaglyph_Reverse_new file to DVBViewer > Shaders folder. Open DVBViewer and select Anaglyph_Reverse_new under View > Shaders. And restart the program and wear your red-cyan glasses. Hey, for me that works great with the "side by side" files (for example the skull rock movie from 3dtv), but NOT with the "up and down files" like the macro show, which you posted the link for. maybe you can open the files with graphedit and post a screenshot from the used filters? regards Quote
ElecardFAN Posted November 13, 2010 Posted November 13, 2010 If you have upside down transmissions you have to change the shader. A simple replacement of tex.x with tex.y should do the trick. Quote
ricabullah Posted November 14, 2010 Posted November 14, 2010 (edited) Hey, for me that works great with the "side by side" files (for example the skull rock movie from 3dtv), but NOT with the "up and down files" like the macro show, which you posted the link for. maybe you can open the files with graphedit and post a screenshot from the used filters? regards Weird here is the ScreenCap of the file of which i gave its link (it's side by side): And here is the graph behind DVBViewer Pro 4.5: _ _ _ _ Edited November 14, 2010 by ricabullah Quote
