Technotrend remote problem
arc03
Hi all.
I have a bit of a problem to set up my TT remote.
I have:
- installed CI/remotesupport for TT card
- MS VC runtime libraries...
- TT remote V 1.1.1a
- enabled TT remote from settings-options-input-inputplugins and from setting I have chosen "usb 2.0 dvb-c card" which is the only option except "none"
Now when I start to teach my remote I first choose the input I want, press "learn" and corresponding button on my remote.
The problem is that, forexample, I want to teach "favourites" - "station minus" and I press "ch-" on my remote, "station minus = TT remote 0".
Next I want to teach "station plus" by pressing "ch+".
Now DVBV ask if I want to "reassign the event, used in : station minus, yes/no". If I press "no" nothing happens, but if I press "yes", "station plus = TT remote 0" and "station minus" is cleared from TT remote command.
If I try to teach any command from remote, pressed button is always "TT remote 0".
I know it works ´cause I have used TT remote earlier, but after clean installation I can´t get it to work.
Anyone...?
I found this while browsing answers to my question. This is from "Technotrend Remote input plugin" thread:
"there is a "ttapi.dll" in your DVBViewer program folder? This is absolutly needed otherwise it wont work." dated 05.01.2007. Is this valid information?
Because I can't find "ttapi.dll", instead there is "ttremote.dll". If it's needed, where can I have it?
  • 3 weeks later...
