shansi Posted June 1, 2010 Posted June 1, 2010 (edited) delete user data and create new data but this error shown Edited June 1, 2010 by shansi Quote
Lars_MQ Posted June 1, 2010 Posted June 1, 2010 Make sure you use the SAME username and password for downloading the Beta as you used for installing the DVBViewer in first place. Quote
shansi Posted June 1, 2010 Author Posted June 1, 2010 (edited) i'm sure my username and password is same as used installing firs place Edited June 1, 2010 by shansi Quote
Tjod Posted June 1, 2010 Posted June 1, 2010 Are you still able to download things from http://www.DVBViewer.com/members/ ? Pleas post you suppot.zip http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Kuni Posted June 1, 2010 Posted June 1, 2010 i'm sure my username and password is same as used installing firs place I think the password/id is also case sensitive. Quote
darkman9 Posted June 4, 2010 Posted June 4, 2010 i have the same problem win 7 4.3.1.150 BETA support.zip Quote
Tjod Posted June 4, 2010 Posted June 4, 2010 Are you still able to download things from http://www.DVBViewer.com/members/ ? Did you ever use a pirate copy on this pc? Quote
darkman9 Posted June 4, 2010 Posted June 4, 2010 Are you still able to download things from http://www.DVBViewer.com/members/ ? Did you ever use a pirate copy on this pc? no i can not download things Did you ever use a pirate copy on this pc? yes Quote
Tjod Posted June 4, 2010 Posted June 4, 2010 no i can not download things Have you bought the DVBViewer Pro? http://www.DVBViewer.com/en/index.php?page=ordering If not everything is like it should be. Did you ever use a pirate copy on this pc? yes If you have used a stolen version, you have to remove everything from the pirate copy (including all configuration files) and remove all changes which the pirate copy had made to your system. Quote
darkman9 Posted June 4, 2010 Posted June 4, 2010 Have you bought the DVBViewer Pro? yes i have bought the DVBViewer Pro i did format my pc and install fresh win 7 but the same it keep ask me the user and the pass on DVBViewer and the website help me Quote
Tjod Posted June 4, 2010 Posted June 4, 2010 Have you posted Files from the Members Section somewhere in the internet? Ore shared your user name? It seams that your user name is blacklisted. Wright a eMali to the address on this page: http://www.DVBViewer.com/en/index.php?page=lost to get the information if your user name is really blacklisted. Quote
darkman9 Posted June 4, 2010 Posted June 4, 2010 Have you posted Files from the Members Section somewhere in the internet?Ore shared your user name? yes i did share some file with my friends Quote
Tjod Posted June 4, 2010 Posted June 4, 2010 Every one how uploads files from the Members Section e.g. a DVBViewer Beta somewhere. Get blacklisted an lose his account for ever (and may by get a software piracy lawsuit). All files in the Members Section are only for DVBViewer Pro customers. Quote
Tjod Posted June 4, 2010 Posted June 4, 2010 Wright a eMali to the address on this page: http://www.DVBViewer.com/en/index.php?page=lost to get the information. But is you one of the b... which are uploading DVBViewer Pro Betas everywhere. You maybe have to switch to a different dvb program or stop watching TV on the PC. Quote
darkman9 Posted June 5, 2010 Posted June 5, 2010 i sent email to bhackbart yesterday but no response Quote
