ramonchin Posted June 6, 2010 Posted June 6, 2010 Hi When I choose to keep the Timeshift recording, the final .TS file doesnt have all audios and subs from the original. Is there anyway to keep everything? Thanks. Quote
Tjod Posted June 6, 2010 Posted June 6, 2010 The timeshift file only contain the audio and subs that are active at the moment. If you like more use recordings and not timeshift. Quote
ramonchin Posted June 6, 2010 Author Posted June 6, 2010 Ok I thought that isn't so difficult. Thanks. Quote
