hulen Posted June 8, 2010 Posted June 8, 2010 HI First of all im very pleased about DVBViewer ! it works very good and i think its the best DVB program i ever tried, BUT i cant get it to work with my CI module and the remote. can any one tell if there is comming an update where it will work ? or is there an addon i can install ? i tried a lot of the addons from DVBViewer site, but nothing works :-( please help me its at Cinergy C PCI HD CI card i got Quote
Lars_MQ Posted June 8, 2010 Posted June 8, 2010 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
hulen Posted June 8, 2010 Author Posted June 8, 2010 well i dont think that DVBViewer supports my card and remote, but here are the file i hope you can help me support.zip Quote
Lars_MQ Posted June 8, 2010 Posted June 8, 2010 Of course it does. It detects it correctly. But the DVB-Card/Driver does not detect the CAM/Smartcard it seems. Quote
hulen Posted June 8, 2010 Author Posted June 8, 2010 that would say that my card should be working with Cam in DVBViewer ? and then i have a driver issue or a faulty card ? Quote
Lars_MQ Posted June 8, 2010 Posted June 8, 2010 well have you done a counter test with the terratec software? Quote
hulen Posted June 8, 2010 Author Posted June 8, 2010 counter test ?? and no ! now im scanning with terra soft to get all channels and try decode with the "original" software, and to see if i can get any info about the reader, if it can be found or not Quote
hulen Posted June 9, 2010 Author Posted June 9, 2010 Thanks for you quick response now i turned the CAM around in the reader and i works ....... (dont tell anyone i had this problem for about a month) again thanks, if it wasent for your help ill never found out i think Quote
