windows 7, task scheduler, .job
BigDear
Hello,
I use DVB task scheduler to program recording. After programming, i have the files .job in the task folder of windows but no in the windows time scheduler (my computer, manage). I take my computer in stand by mode. The problem is that the computer don't wake up at the right time to record.
I use too other program (ProgDVB) to schedule task and i have not problem but I want to use DVBViewer (it's better).
best regards
Edited by BigDear
  • 10 months later...
I've the same problem. Since I installed windows 7, Task scheduler works when PC is on. It doesnt awake it from sleep.
Its very annoying since I cant schedule it for recording my favourites tv programs.
Has anyone found a solution?
Thanks.
Edited by ramonchin
Check you BIOS for settings which disable timer wake up like "EuP 13".
And check the Windows energy settings. If there timer wake up is disabled.
Bios is right and timer wake up is enabled.
Ok. Its solved.
I had to "run as administrator" both programs: DVBViewer and task scheduler.
Thanks.
