notfast Posted June 10, 2010 Posted June 10, 2010 1. Device manager show 4 WinTv HVR-930C hybrid tuner installed. 2. DVBViewer find 4pc WinTv HVR-930C (BDA) tuner as DVB-T and only 1pc as DVB-C <- The problem ! 3. DVBLink TVSource finds 4 DVB-C tuner and they all works fine 4.TransEDIT also finds 4 DVB-C tuner and i can scan them all 4 and find my channels on all of them, but i cant save/export the list to DVBViewer :-( MediaPortal can use all 4 tuner as DVB-C tuner, I just cant figuar out why DVBViewer can't, when all other software can use them all. Quote
Lars_MQ Posted June 10, 2010 Posted June 10, 2010 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Lars_MQ Posted June 10, 2010 Posted June 10, 2010 There is a bug in the 4.2.1 which keeps the DVBViewer from correctly detecting multiple HVR-930C. This has been fixed in the current beta. Quote
notfast Posted June 10, 2010 Author Posted June 10, 2010 There is a bug in the 4.2.1 which keeps the DVBViewer from correctly detecting multiple HVR-930C. This has been fixed in the current beta. Thank you :-) I´ll try the beta. Quote
