Two shutdown warnings
Kommakul
Hi
I use DVBV and RS on the same machine. Is it possible to avoid having two shutdown warnings after a timed recording? I get one OSD message from DVBV but also a regular window from RS. (which is not in focus)
My suggestin would be: if DVBV is in front: only show OSD warning. Else show RS warning (so i get the warning if DVBV is minimized)
Is it possible to obtain something like this in the current versions? (4.3.1.150 and 1.6.0.0) Else consider this as a feature request... :whistle:
Regards
Christian
afik only way by now is to deactivate the RS warning (rightclick RS Symbol -> dont warn on shutdown)
Thanks
:biggrin:
