Can't find any channels
Pasjes
I'm running Windows 7 64 bit under Bootcamp on a Macbook Pro. Have just reformatted my system. Was previously running Win7 32 bit and had DVBViewer working fine.
Since reformatting and re-installing I just can't scan any channels at all. I've got a DVICO Fusion USB tuner with the Bellbird drivers...The FusionHDTV software scans my channels just fine and picks them all up no problems by DVBViewer isn't finding anything.
I've used Transedit as well and nothing!
Any help greatly appreciated.
Im almost sure nobody has DVBViewer working on a Mac, cuz it is Windows software.
Emulating windows has its drawbacks and limitations. I can imagine you are still using the Macs hardware and drivers and that would present itself as a problem. I could imagine DVBViewer needs real windows BDA-drivers to talk with.
Edited by majstang
Windows 7 runs "natively" on a mac with bootcamp, you just do a dual boot like any other pcs. No emulation needed.
I think there's some kind of incompatibility between 64bit drivers and DVBViewer.
