Nimloth Posted June 11, 2010 Posted June 11, 2010 Hello, what's code in Actions.ini is for enabling in OSD Extended Exit (list where you can Clise DVBViewer, Power Off, Standby, etc) ? Many thanks, Lukasz Quote
Tjod Posted June 11, 2010 Posted June 11, 2010 To enable the extended Exit Options > Shutdown > extended Exit or to get it in the OSD-Menu Options > OSD Menu > enable Extended Exit. Quote
Nimloth Posted June 11, 2010 Author Posted June 11, 2010 Thx - 1st option was what I was looking for Cheers Quote
