hdahl Posted June 11, 2010 Posted June 11, 2010 Hello! Is it possible to basically have recording to be continously on for a channel, when a new program starts a new recording should be begun and together with the video file the EPG information for the program should be saved using the Xml format in a separate file having the same name as the video but .xml as the extension? Best regards, Henrik Dahl Quote
hdahl Posted June 11, 2010 Author Posted June 11, 2010 OK, so what if we limit it to: Is it possible to basically have recording to be continously on for a channel, when a new program starts a new recording should be begun and skip the EPG consideration? Quote
