Arjan-- Posted June 12, 2010 Posted June 12, 2010 Hello I'm new with DVBViewer The only point of DVBViewer I dislike is the channel list so I downloaded the Channellist Editor. I start and load channels.dat then I make on the right my own list and save it as eigen.dat How do I set DVBViewer to use eigen.dat? Use the recent beta version DVBViewer 4.3.1.150 BETA Quote
xarko Posted June 12, 2010 Posted June 12, 2010 How do I set DVBViewer to use eigen.dat? I never used the Channellist Editor. But why don't you just close DVBViewer, rename the old channels.dat to channels.dat.bak and rename eigen.dat to channels.dat and start DVBViewer again. Sounds logical. Wouldn't that work? Quote
