B2C2 Non BDA Mode
pkcahier
Is there any chance we could get the network mode for B2C2 cards?(windows 7 x64 here)
The BDA driver is quite bad(currently requires reboot quite often) and if I use the network driver then the card does not appear in the devices list.
The DVBViewer supports the B2C2 WDM driver since more than 8 years.
When I am using the network mode(skynet.inf), the card does not appear when scanning for devices. Any suggestions as to why that happens?
You have to install the entire technisat application not only the driver.
I stand corrected there, indeed.
It was not that obvious that the application needed to be installed for DVBViewer to detect the interface.(In particular, other dvb applications seemed to be able to use directly the interface)
It might be a good idea to note that somewhere easy to find:)
