Recording service unicode support
oliverwestall
I performed a fresh install of the DVBViewer 4.2.1 and recording service 1.6.0.0, but I still have problems displaying Chinese characters within the EPG (i.e., "???????" rather than normal Chinese text).
I am using US English version of Windows XP SP3, regional settings set to Chinese, recording service language and EPG setting all set to Chinese.
Any advice on how to get it to work?
Thanks!
Edited by oliverwestall
DVBViewer 4.2.1 has no unicode support...use the beta instead!
Just installed the latest beta (4.3.1.150) over existing installation, results still the same.
the support zip shows a recording service version 1.5.2. Reinstall the 1.60 version and check again
