patti Posted June 16, 2010 Posted June 16, 2010 Here is a small piece of vbscript that I wrote to suit my needs to prevent my dedicated HTPC from shutting down if I press the power button on my remote while recording service or DVBViewer is recording. The script comes in three parts. First part is the script itself that does the checking of ongoing or soon to start recordings. The second part is command.vbs which is placed in DVBViewer's scripts folder and it checks for remote power button press. Third part is a new action to DVBViewer's actions.ini which defines a new action number for the shutdown script. Here are the three parts, first the action for actions.ini. Add the following line at the end of actions.ini and save the file. You also need to adjust your remote settings to bind that action 25000 to your remote's power button. How to do it depends on what remote you use and whether you use DVBViewer's internal remote input or Girder like I do or something else, so I am not going into detail with that. IntelligentShutDown=25000 Next add this piece of script to Command.vbs in DVBViewer's scripts folder. If command.vbs already exists then leave out Sub and End Sub definitions and add the rest of the code between existing Sub..End Sub definitions. If Command.vbs does not exist in your system then just create the file with the code below. Remember to set the path in execnewprocess to point to your scripts directory where you save the actual IntelligentShutdown.vbs script. Sub main(command) set oDVBV=getobject(,"dvbviewerserver.DVBViewer") If command = 25000 then oDVBV.osd.execnewprocess "c:\windows\system32\wscript.exe","C:\Users\tv\Desktop\DVBViewer\scripts\IntelligentShutdown.vbs",false,false End If End Sub Third, here is the actual code that checks the recordings and decides whether to justshut down the monitor or put the computer in standby: Dim DVBVRecording Dim DVBVActive Dim DVBVRecordingSoon set oDVBV=getobject(,"dvbviewerserver.DVBViewer") '======================= ' ongoing recording check '======================= DVBVRecording = FALSE For i = 0 to oDVBV.timermanager.count-1 If oDVBV.timermanager(i).recording Then DVBVRecording = TRUE ' recording going on End If Next ' ============== ' Next recording ' ============== DVBVRecordingSoon = FALSE NextRecordingStart = oDVBV.timermanager.nextrecordingtime If NextRecordingStart <> 0 AND NextRecordingStart < dateadd("n",15,now) Then DVBVRecordingSoon = TRUE ' recording starting in 15 minutes End If ' ===================================================================================== ' check both ongoing recording and a recording starting in 15 mins and act accordingly ' ===================================================================================== If DVBVRecording OR DVBVRecordingSoon Then oDVBV.OSD.ShowInfo "SHUTDOWN STATUS","Recording active! Will just shutdown monitor.","",10,"" oDVBV.SendCommand(16383) ' close graph oDVBV.SendCommand(12328) ' shutdown monitor Else oDVBV.SendCommand(12324) ' standby computer End If That's it, restart DVBViewer and see how the script works. If I forgot some important steps then forgive me, it is already past midnight here... patti Quote
majstang Posted June 16, 2010 Posted June 16, 2010 Works only if Client is started (in other words COM must be registred), yes? Quote
nuts Posted June 16, 2010 Posted June 16, 2010 (edited) Yes. And because of that - some errorhandling after oDVBV=getobject(,"dvbviewerserver.DVBViewer") would be good. Edited June 16, 2010 by nuts Quote
patti Posted June 17, 2010 Author Posted June 17, 2010 (edited) Works only if Client is started (in other words COM must be registred), yes? Yes, but that is not a problem for me as I use only remote to shut the HTPC down and my remote doesn't work without DVBViewer. As I said, this is for a dedicated HTPC, for mixed use it might not be as useful. Also the recommended error handling would not do much good because if DVBViewer is not running then the whole script does not execute and thus there is no need for error checking patti Edited June 17, 2010 by patti Quote
majstang Posted June 17, 2010 Posted June 17, 2010 (edited) Yes, but that is not a problem for me as I use only remote to shut the HTPC down and my remote doesn't work without DVBViewer. As I said, this is for a dedicated HTPC, for mixed use it might not be as useful. Also the recommended error handling would not do much good because if DVBViewer is not running then the whole script does not execute and thus there is no need for error checking patti Ok, but if folks wanna use your script for automating purposes there would be great if there is some error handling, cuz if client is not running the script fails accordingly. This is how I would solve it: On Error Resume Next strComputer = "." arrTargetProcs = Array("DVBViewer.exe") Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") For Each strTargetProc In arrTargetProcs Set colProcesses = objWMIService.ExecQuery _ ("SELECT * FROM Win32_Process WHERE Name='" & strTargetProc & "'") If colProcesses.Count = 0 Then Set WshShell = WScript.CreateObject("WScript.Shell") Return = WshShell.Run("""C:\Program\DVBViewer\DVBViewer.exe""", 1, true) Set WshShell = Nothing End If Next Tested and works for XP. Place code first in script. Code checks if client exist...if not it is started. Edited June 17, 2010 by majstang Quote
patti Posted June 17, 2010 Author Posted June 17, 2010 (edited) Ok, but if folks wanna use your script for automating purposes there would be great if there is some error handling, cuz if client is not running the script fails accordingly. This is how I would solve it: What kind of automating purposes do you have in mind? I have another script that is still unfinished and I check the existence of DVBViewer this way: Const DVBVPath = "C:\users\tv\desktop\DVBViewer\beta\DVBViewer.exe" On Error Resume Next set oDVBV=getobject(,"dvbviewerserver.DVBViewer") if Err <> 0 Then set oShell = WScript.CreateObject("Wscript.Shell") Result = oShell.Run(DVBVPath,1,FALSE) Err.Clear Wscript.Sleep(10000) ' delay to let DVBV start before trying to create oDVBV again set oDVBV=getobject(,"dvbviewerserver.DVBViewer") end if patti Edited June 17, 2010 by patti Quote
majstang Posted June 17, 2010 Posted June 17, 2010 (edited) What kind of automating purposes do you have in mind? I have another script that is still unfinished and I check the existence of DVBViewer this way: Well, i thought it would be neat to have a post recording standby/hibernation script which behaves in different ways depending on if a number of variables comes back as true or false. Most parts of your excellent script can be used for that purpose. A goal for me is to fully automate things as far as possible. You had problems before executing your COM scripts (if I remember it right) through recording service....how did that go...did you find some solution? Edited June 17, 2010 by majstang Quote
patti Posted June 17, 2010 Author Posted June 17, 2010 (edited) Well, i thought it would be neat to have a post recording standby/hibernation script which behaves in different ways depending on if a number of variables comes back as true or false. Most parts of your excellent script can be used for that purpose. A goal for me is to fully automate things as far as possible. You had problems before executing your COM scripts (if I remember it right) through reording service....how did that go...did you find some solution? My second script is just what you describe above: "post recording standby/hibernation script which behaves in different ways depending on if a number of variables comes back as true or false." I want DVBViewer to behave intelligently depending whether it is a scheduled unattended recording or if the recording stops while I am watching TV. I hate it when DVBViewer tells me "Recording service is going to shut down the computer in XX seconds". It usually happens when I am away from my sofa and cannot react to it. So what I have in mind is a script that checks whether I am actually watching tv or a media file (=graph active) and then post recording task would jsut stop the recording and do nothing else. When the graph is not present during a recording it means that it is an unattended scheduled recording or I have shut down the monitor via above script when going to sleep for example and TV needs to shut down after the recording. Is this sort of what you are trying to do too? Yes, I had problems with rec. svc's post recording tasks accessing DVBViewer's COM interface to read the information needed for what I just described above. The explanation and reason of my problems can be found here: http://www.DVBViewer.tv/forum/topic/40427-why-isnt-my-script-executing-as-a-rec-svc-task/page__pid__300256#entry300256 As a solution I have been thinking of running rec svc as a session 1 application through the use of psexec from Sysinternals which can define which session to use. I have not really got into it yet but somehow I will start the service in session 1 some day This session 0/1 problem only affects OS'es starting from Win Vista. Win XP service can interact with DVBViewer no problem since they run in the same session 0. patti edit: Hmm, I just read the WHOLE document that is included in my above link and realised it offers my solution. I had only read the session 0/1 part of it before and never the whole document. I'll try the methods desscribed in the document right a way... Edited June 17, 2010 by patti Quote
majstang Posted June 17, 2010 Posted June 17, 2010 Is this sort of what you are trying to do too? Thankfully i have XP, so i dont have to deal with the Win7 issues you are describing. So, my script kind of reminds of yours, but includes more variables. Such as one behaviour during weekdays and another during weekends. Time of the day variable. Hibernation if no recording is due within 30 minutes between 01.00-16.00. No hibernation between 16.00-01.00. If RS is recording or not. With that many variables it is getting a little too complicated I think Quote
patti Posted June 17, 2010 Author Posted June 17, 2010 With that many variables it is getting a little too complicated I think Well if it works it doesn't matter if it is complicated or not It would be nice if recording service had scripting support to read it's state without the need to start DVBViewer/COM for that. Your solution of reading recording service's recording status through taskbar icon is an ingenious one! Quote
