Trance Posted June 17, 2010 Posted June 17, 2010 Hello, I noticed that each time after rebuild graph or scan the CAM is re-initialized. So I have to wait a bit to get the picture on encrypted channels. Is it possible to make an "always on" functionality for the CAM? This occurs on DVBV Pro 4.2.1 and on the latest beta. I didn't check the previous versions. My hardware: Technisat SkyStar HD (same as TT-budget S2-3200) with latest TT's bda drivers CAM: Technisat CX (Conax) with latest firmware. Quote
Lars_MQ Posted June 17, 2010 Posted June 17, 2010 No this can not be changed, cause a rebuild also open/closes the DVBViewer. So best thing to do: don't rebuild the graph or scan when you want to watch TV. Quote
Trance Posted June 17, 2010 Author Posted June 17, 2010 Unfortunately, but quite often it is necessary to rebuild graph due to stop streaming (especially on channel change). I noticed one more strange thing - when I change from encrypted to fta channel I have a discontinuities (3-5). Video/audio is corrupted for a split second. Same thing is when the CAM is initialized on the fta channel (for example, after restart DVBViewer). At the time of initialization I have the same discontinuities. Is there an option to send only encrypted channels to CAM? Maybe this will eliminate the discontinuities? Quote
Benarty Posted June 25, 2010 Posted June 25, 2010 if you get streaming errors while zapping , some OSD's with additional scripts can cause this , in that case, you should switch back to the default DVBViewer OSD and see if the problem is still there. If not.. hint.If You are using other plugins also, time to remove them. Quote
