DVBViewer in windows media center
balky
I was wondering if anyone has succeeded in making it possible to start DVBViewer from inside windows media center...
Since this is possible with the firedtv viewer I kinda guess someone might have tried with DVBViewer...
If yes, how did you do it?
And as well, if our top notch DVBV gurus can give ideas, it will be quite helpful...
Thanks.
The answer is here. But at a price of course.
http://www.dvblogic.com/tvsource.php
I tried it a while ago, and I think the tool is crap...
As at the time I checked it out, had no support for diseqc 1.3 or USALS... raw diseqc commands supported on limited hardware...
The tool is quite sub-standard in my opinion...
