Video Recorder Plugin
Can the author of this plugin make it possible for user to add more PIDs to the active channel & save changes. In case this function is already functional, please advise how to do that.
THX
Edited by fundom
  • 7 months later...
I have a similar demand, so I see no reason to open new thread.
For some reason (bug?) the video recorder plugin ignores additional PIDs selected in the relevant field.
It does this when many items are selected to be recorder, for example if I select all services from one transponder.
While on the subject of recording, is there any way to record the complete transponder as it comes down from the satellite?
It says so on the features of DVBViewer but can't find the way.
Just a note. The DVBViewer will not record from a fully scrambled transponder. There must be at least one FTA channel.
It's possbile to record scrambled channel with ECMs and descramble using [removed]?
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras&section=boardrules
Edited by Tjod
Forum Rules
