older Version
coolworm
Can someone send me to my e-mail georgea@trinityvision.gr one version back from DVBViewer 2.1 because i have to many problems with 2.1.
thanks!
which problems you have with new version which not exist with older version?
Steffen
i can`t resize subtitles and a lot of traffic of b2c2 network card and every 30 second the picture freeze and goes again.
sounds like copy protection.....
what do you mean copy protection?? i try to watch ad-space to nilesat101 it`s free!
when i use progdvb it`s working fine! p.m i have buy DVBViewer!
Maybe you put in the wrong data during installation in the DVBViewer and so you've got this reaction of the viewer.
picture freezing every 30 seconds is a feature of the copy protection of the DVBViewer !
Steffen
i`ve made reinstall the windows and install DVBViewer. so i think my only solution is the older or newer version of DVBViewer! i install also and DVBViewer 1.9R1 i think and i don`t have that problem!
thanks
You think or you know?
Your data you can find under HKEY_LOCAL_MACHINE/Software/CM&V/DVBViewer and there you can have a look. Maybe you have an typo error...
Steffen
i don`t remember which version i have but it`s to old! ok!
i`l wait for the new version ! hackbard fix the high traffic to network!
thanks for the help!
