Ale Posted June 20, 2010 Posted June 20, 2010 HI! I have a Skystar1 that I use in soft mode under ProgDVB, can I use under DVBViewer also? Under which version? How? Thank you all!! Quote
Lars_MQ Posted June 20, 2010 Posted June 20, 2010 The fullfeatured skystar 1 is NOT supported by the DVBViewer. Quote
