hygrometrics Posted June 2, 2004 Posted June 2, 2004 Hello everyone, Is it possible to to use DVBViewer with the Hauppauge Nova-S card? If yes, is there a way to test the combination before buying the program? The test version seem to work with only with the Sky Star 2. Quote
Guest DAvenger Posted June 2, 2004 Posted June 2, 2004 Currently, only SS2 is supported. However, there is a high probability that support for other cards will be added later this year. Quote
