Superbanana Posted June 23, 2010 Posted June 23, 2010 I would like to record programmes in MPEG-PS (.mpg) format with subtitle. But I found that no subtitle track is present in the .mpg file. It only works when I change the recording format to MPEG-TS (.ts). Is it possible to record subtitle with .mpg format? Quote
Lars_MQ Posted June 23, 2010 Posted June 23, 2010 Only in the TS Format you can record DVB-Subtitles. Quote
Superbanana Posted June 23, 2010 Author Posted June 23, 2010 Thanks for your reply! Is there any way to hard encode the subtitle into the video? I would like to watch the video with subtitle on iPhone. Thank you very much! Quote
Lars_MQ Posted June 23, 2010 Posted June 23, 2010 Yes certainly, you just have to use a software, which takes the TS and reencode it with the subtitles. Of course this will take some time and the quality will also suffer... Quote
