DVBViewer 4.2.1 Subtitle and EPG problems
litiuion
HY...
EPG and subtitles do not work with DVBViewer 4.2.1.
I'm from Romania and I bought a combo cablestar TechniSat hdci. Subtitling work with DVBViewer 3.8.0. What should I do? Thanks
Sorry for the careless. I attached files. Sorry for my bad english
pls help...
Edited by litiuion
this not a support.zip. Stop manipulating the archive and post the original.
I think the problem is the file "setup.exe".
because when i replaced the file with version 3.8.0.0, subtitling work properly, but lacks other features
thx
I solved the problem with subtitles. I moved the folder "CMUV" from Program_data, and I installed DVBViewer 4.3.1.150 Beta. Subtitle works perfectly.
EPG problem remains.
